mid throttle cutting out
cl77blackcafe
i have a 66 cl77 that is cutting out mid throttle runs great other than that... float adjusted with the guage,good plugs etc etc etc...ive read most of the post and tried it all...140 jets w straight pipes..let me kno what uve done if youve had this problem...also installed new points that are arking any suggestions to any of these problems im having!!please send help!!!!
Re: mid throttle cutting out
Ya may want ta spray the points with a contact cleaner then draw a business card through them when they are closed. ..............lm
cl77blackcafe wrote:i have a 66 cl77 that is cutting out mid throttle runs great other than that... float adjusted with the guage,good plugs etc etc etc...ive read most of the post and tried it all...140 jets w straight pipes..let me kno what uve done if youve had this problem...also installed new points that are arking any suggestions to any of these problems im having!!please send help!!!!
cl77blackcafe
well i just replaced points and condenser....(new both) and have tried EVERY clip position,so far ran the best in the middle position...i mean it idles great starts great zips around great but when you start getting into the throttle is doesnt die but cuts out i really think i have tried everything but if the problem persist i have obviously missed something...im not sure if you would call it arking but i noticed some yellow spark behind the breaker arms(what makes contact w the points shaft) coming from the point contacts.i contacted bill silver last fall because it would go over 20mph he set me up w 140 jets from the stock cuz i am running dream low staight pipes(at the time cl77 hi pipes)ive done the pull the choke while ur riding trick it does cut out that is supposed to indicate whether you are too lean so i assume from the results of that i am close to being right with the mix...air screws are 1 1/2 out ...could it be rectifier...it charges fine holds ,charge fine...idk it is such a kick a@$ bike and just want it to be tip top.....thanks guys and thankyou ever so much for the humble and thoughtful welcome to the site ...nice people truly do ride hondas..LOL!
cl77blackcafe
cl77blackcafe
D13 is the size of needle jets w 140 main jets...its running straght pipes,was just wondering if they disagree w each other...any experts out there know...ive had this bike for a year and its been all work so i am new at the honda twins and need any help i can get...was running good up until 40 mph when i try to accellerate from there it cuts out ,also with heavy acceleration thru the gears
