wtb c76 parts
Doum
wtb c76 parts
Post by Doum » Sat Mar 03, 2012 12:49 pm
I just bought a 1960 c76,I'm looking for some parts,someone have used parts for sale?
Eljeef
Post by Eljeef » Sat Mar 03, 2012 2:39 pm
Welcome. Some suggestions: Post some photos if you can. A picture will speak volumes about what you have and what you need. Use the search engine, there are many, many posts that cover almost every topic. Put your location in your avatar. There may be somebody nearby that could share your interest in vjmc's and you will simply have more responses if people can relate you to a geographic location. I have a C77. I wonder how much difference there is. Post your engine serial number and your frame number (you'll find that below your battery box and slightly to the left as you are looking at the bike.) I look forward to seeing your bike. :-)
1964-C77 305 Dream
2002 BMW R1150GS
Doum
c76
Post by Doum » Sun Mar 04, 2012 12:00 am
I'm in quebec,canada
I try for a picture not sure if it will work.
The frame been changed,I have the original frame but in VERY bad condition.The lower part of the frame been saved and swaped on another frame.Need a lot of work,but motor have a good compression.Bike is 95% complete,with title!
serial c76-60-10387
Question,I need front exhaust pipes,I have compare the pipe with olds cb77 and they have a very small difference in bent,did the c77 front pipe are the same as the cb77 or maybe by change the c77 pipe will fit the c76....?
jensen
Post by jensen » Sun Mar 04, 2012 3:25 am
You have a very rare bike, a C76, these bikes don't come up that much.
Welcome to the everything is just a little different show, because that is what it is.
First type dreams : C70 / C75
Second type dreams : C71 / C76
Third and last type dreams : C72 / C77
The C77 has a wet sump engine, the C76 has a dry sump engine.
The C76 has ignition timing via the crank, the C77 has ignition timing via the camshaft.
Is it a Japanese or non japanese version ? (shifting is different)
The list of differences goes on and on.
For the mufflers and pipes the same story, these seems to be the same, but are not.
Some bodyparts of a C77 will fit, some not.
Take a look at www.cmsnl.com for parts lists of a C76 versus a C77, and you will see what I mean,
Good luck with your rebuild.
Maybe you can contact Jelle, a Dutch specialist on early Honda dreams, he is a member of this forum,
btw, I'm interested in your winkers, can you make and post a detailed picture of them ?
Doum
exhaust
Post by Doum » Sun Mar 04, 2012 7:56 am
Someone have the 2 model of pipe? c77 and cb77,put it side by side and take some picture
jensen
Post by jensen » Sun Mar 04, 2012 10:05 am
Seems that you're not interested in my writing and the time it took to write it down, therefore I will not walk to my atic, unpack my C77, CB77 and C71 mufflers and take pictures, to much work I have to do for someone who's not responding to my reply in any way,
good luck,
Doum
Post by Doum » Sun Mar 04, 2012 12:20 pm
Sorry,I read your post,I read a lot about this model and did a lot of search,thank for the comment,but I read all the same information many place on internet.Most of information are always the same everywhere.
