looking for early cb77 front fender
burnite2
Post by burnite2 » Thu Dec 01, 2011 11:27 pm
looking for early cb77 front fender for a 63. i have a late superhawk fender that is up for trade for a late one. i'm also looking for a right side engine cover and dynamo cover for a superhawk.
Jeremy
Atlas
Post by Atlas » Fri Dec 30, 2011 10:18 am
Hi, Don't know if you already found what you needed but if you hav'ent i may be able to help. I scraped out a stuck superhawk for the tranny needed for my dream. Front fender is in pretty good shape but not sure what year, did'nt know there was a difference. Should have whatever else you might need. Atlas
Post by LOUD MOUSE » Fri Dec 30, 2011 10:29 am
Are ya aware that the CB trans gears are totally different than a Dream?. ....lm
Atlas wrote:Hi, Don't know if you already found what you needed but if you hav'ent i may be able to help. I scraped out a stuck superhawk for the tranny needed for my dream. Front fender is in pretty good shape but not sure what year, did'nt know there was a difference. Should have whatever else you might need. Atlas
burnite2
Post by burnite2 » Fri Dec 30, 2011 7:27 pm
PM sent
Jeremy
Atlas
Post by Atlas » Sat Dec 31, 2011 10:30 am
The trans gears were different in the cb so i installed the entire gearset from the superhawk to the dream and it worked perfectly. Rode my 62 dream all summer. Atlas
burnite2
Post by burnite2 » Sat Dec 31, 2011 12:02 pm
The fender i need is one that will fit the steel slider fork leg. the center mount has a curve in it making it look kinda like the letter J. I also need the correct speedo, i need the tach and speedo rotate in the opposit directions, the headlight ring, starter soliniod, starter button assembly and wiring, generator cover, and a right side engine cover. The fender is what i need the most, pictures would be great to make sure its the right one. My e-mail is burnite2@hotmail.com.
thanks,
Jeremy
