ca77 regulator rectifier
BCSANDERS
Post by BCSANDERS » Thu Aug 18, 2011 5:57 am
Can you use the solid state modern rectifier on the Honda ca77?
I used one on my 1961 Triumph as it used a similar old type which was almost impossible to find and it works fine not sure about the Honda.
Hahnda
Post by Hahnda » Thu Aug 18, 2011 8:31 am
The short answer is yes. What type are you thinking though? All it needs is a real simple one like this.
BCSANDERS
Post by BCSANDERS » Thu Aug 18, 2011 8:59 am
Thanks.
Yes that is the type I used on the Triumph.
brewsky
Post by brewsky » Thu Aug 18, 2011 4:28 pm
I've been using the Radio Shack one for a couple years now with no problems.
http://www.honda305.com/forums/viewtopi ... adio+shack
lifewithoutparole
Solid state rectifier
Post by lifewithoutparole » Thu Aug 18, 2011 8:52 pm
I put one on my 67 S90 several years ago..worked great. Then bought my 67 CL77 in may and immeiately replaced the stock one with a solid state rectifier from the same guy who supplied the S90 one...oregon motorcycle parts...23.00 great quality and with the correct connector!
BCSANDERS
rectifier
Post by BCSANDERS » Fri Aug 19, 2011 7:20 am
Thanks for that I have contacted Oregon motorcycle and they are supplying a unit for me.
conbs
Rectifier replacement
Post by conbs » Mon Aug 22, 2011 12:57 pm
RetroBikes in Port Angeles Washington has a modern replacement rectifier that looks just like the original.
