speedo buzzing loud and reading 120mph at 25 mph
johnnyroastbeef
Post by johnnyroastbeef » Thu Aug 11, 2011 6:41 am
Ok i'm new to the forum but i've learned tons already from readin old post. I've searched this topic but found nothing. My 68 Super Hawk just got back on the road after being in a garage for 25 years. it runs really well and teh speedo worked on my first test drive but i fear i've damaged the cable or something worse in the speedo. when i rode it yesterday the tach worked fine but the speedo, (all of a sudden,) started buzzing and the needle sprung all the way over to the max mph. I was wondering if it could be smoething as simple as a broken cable or something more complex? If anyone could offer some advice i'd really appreciate it. Much Thanks in advance.
-Oh and I'm in South East PA btw. Thanks
Re: speedo buzzing loud and reading 120mph at 25 mph
Post by LOUD MOUSE » Thu Aug 11, 2011 6:57 am
Welcome.
Ya may want ta remove and clean the cable then lube with white grease. ...................lm
johnnyroastbeef wrote:Ok i'm new to the forum but i've learned tons already from readin old post. I've searched this topic but found nothing. My 68 Super Hawk just got back on the road after being in a garage for 25 years. it runs really well and teh speedo worked on my first test drive but i fear i've damaged the cable or something worse in the speedo. when i rode it yesterday the tach worked fine but the speedo, (all of a sudden,) started buzzing and the needle sprung all the way over to the max mph. I was wondering if it could be smoething as simple as a broken cable or something more complex? If anyone could offer some advice i'd really appreciate it. Much Thanks in advance.
rustywrench
speedo
Post by rustywrench » Thu Aug 11, 2011 10:19 am
Jrb,
If after you clean and lube the cable as advised; you may need to dis-assemble the speedo itself. Go to G-man's post on speedos and follow his tutorial on getting it apart. The lower bearing gets dry and causes all kinds of havoc. Spray the bearing with a good solvent, then dry and lube. Don't let this process intimidate you, it's really easy to do. Rusty
johnnyroastbeef
Re: speedo
Post by johnnyroastbeef » Thu Aug 11, 2011 10:26 am
rustywrench wrote:Jrb,
ok i'll do that but if you coudl, could you explain how I'd go about findning G-man's post? (Rookie question i'm sure!)
jleewebb
speedo
Post by jleewebb » Thu Aug 11, 2011 10:29 am
Before disassembling your speedo you might try removing it from bike, turn it upside down, and drip a few drops of light machine oil down the cable hole. turn it right side up pretty quickly or you'll get a ring around the needle on the speedo face. You can test it with an electric drill before you put it back on to see if that fixes it. I found a large cotter pin that fit in place of cable to spin mine with drill.
'62 CB77. "It's a rider."
rustywrench
speedo
Post by rustywrench » Thu Aug 11, 2011 11:02 am
Look to the yellow menu on the left and click on search. Once there, "speedo clean" or "speedo lube" will get you into some interesting reading. Note that most are of cl77 speedos but yours should not be much different. Rusty
Rock160
Post by Rock160 » Thu Aug 11, 2011 11:08 am
Your search - "speedo clean" - did not match any documents.
Your search - "speedo lube" - did not match any documents.
