Cb77 1966
Not running. Just got everything put back together. Now when I went to strt for the fort time the left spark plug is not sparking and the right coil is getting warmer. I had the frame powder coated but I filed all grounding points down. And I just trimmed the spark plug wire. But still no spark
CB77 no spark left side
Seanmichaelwood
Getting power to the coil? Black wire to + side of coil, yellow wire to - side of coil? Power to the points? Yellow wire connected to points correctly, all fibre washers in correct so wire is not grounding?You can also switch the green and yellow wire and see if the issue changes sides.
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
