ca77 maintneance specs.
versuspop
Post by versuspop » Wed Jul 13, 2011 3:07 pm
Great info! Thanks oldstan. Any opinion on top end gasket sets, and where to procure a high quality set?
65 CA77
66 CB77
71 CB450
73 CB350F
OldStan
Post by OldStan » Wed Jul 13, 2011 3:15 pm
I haven't run my engine yet, so I'd hate to give an opinion there, but I got my complete set from Retrobike;
http://www.olypen.com/retro/
63 CA78
teazer
Post by teazer » Wed Jul 13, 2011 6:08 pm
I'm the wrong guy to ask about gaskets. I buy whatever is available at a swap meet or anywhere else if they are cheap. I also modified stock head gaskets to fit bigger pistons and only once did I get a leaky gasket - and it had been professionally made.
So my conclusion is any gasket will probably be fine.
With Pistons, I want to want forged pistons but I have melted a few and have never had a cast piston fail even when modified and thrashed mercilessly. Either will work, but the theoretical advantages of a forged piston that needs more clearance is not there for a street motor.
I had forgotten what you were trying to do here. If you want just the next size up .25mm or 0.50mm and Ohio has them, that's the way to go as long as they have rings to match. That's what I would do on a Dream.
The next cheapest option is Bore-tech cast pistons plus liners to push it out to 65mm and I wouldn't worry about the CR issue too much or Tim McDowell's cast pistons to get back to stock 60.0mm and modify the had to get CR back. I might do the Bore-Tech thing If I wanted more cubes.
I'd also look on ebay to see if anyone is selling NOS O/S pistons and rings
versuspop
Post by versuspop » Wed Jul 13, 2011 6:29 pm
Thanks again, everyone!
65 CA77
66 CB77
71 CB450
73 CB350F
versuspop
Post by versuspop » Wed Aug 10, 2011 9:26 am
Really? I just read in bill's manual that the cb/cl pistons will raise compression slightly.
Further, What is up with the "high compression" cb/cl pistons 13102-268-010.
i am about to finally purchase pistons and rings and i feel like i need some hand holding.
it looks like my choices are:
CA .25 pistons for 40.00 each from ohio cycle 13102-266-020
or
CB "high compression" pistons from ohio cycle for 25.00 each 13102-268-010
Nick does not have any .25 rings listed.
i know that with the 266 pistons, i use the 266 rings which are the thick type.
what rings would i use if i went the CB piston route? 275?
Sorry for all the questions. I am really nervous and in territory unfamiliar.
Ian
LOUD MOUSE wrote:Those are CB/CL77 pistons and will lower the compression. ..........lm
G-Man wrote:
LOUD MOUSE wrote:I didn't know Tim sold DREAM piston kits. .........lm
versuspop wrote:So it looks like I am in the sh$$. I need my cylinders bored out and new pistons. I need to move up to .25 over. Tim McDowell sells a kit for $300. Is there a cheaper option? It seems like Ohio cycle sells pistons (266-020) for around 40 a piece though. It looks like I could save bout 100 if I piece a kit together. Is this a bad idea? Also, do I need to do anything to the head (valve area) if I get this job done?
Lastly, though i am sure I have seen info before, I can not find it now- what is the difference between ca and cb pistons?
Looks like Tim does a kit.
http://www.classichondarestoration.com/ ... d_222.html
$389 though - sounds quite a lot.
65 CA77
66 CB77
71 CB450
73 CB350F
Post by LOUD MOUSE » Wed Aug 10, 2011 10:45 am
268 are 250cc pistons.
266 is for the 305 DREAM.
The CB/CL pistons will lower the compression when installed with the DREAM head.
Ya want the 266 pistons and the 275 rings. (NOT THE THICK ONES). ............lm
versuspop wrote:Really? I just read in bill's manual that the cb/cl pistons will raise compression slightly.
or
Ian
versuspop
Post by versuspop » Wed Aug 10, 2011 11:40 am
Perfect. Thanks!
65 CA77
66 CB77
71 CB450
73 CB350F
