New 66' Dream Owner w/ a Few Questions! Please help!
Tango911
Post by Tango911 » Fri May 20, 2011 8:22 am
part of LOUD's question was, is there spark on both plugs, specially the one dripping gas?
sounds like you need to check the spark, then you need to pull the carbs and clean'em.
Ehonda
Spark
Post by Ehonda » Fri May 20, 2011 8:25 am
Im sorry if this is a dumb, NOOB type question.. But, what is the proper way to check the "spark", and also would you reccomend just buying new plugs and be done with it?
pknopp
Post by pknopp » Fri May 20, 2011 8:42 am
It's possible but not likely that new plugs will just solve your problem. Whenever I start on a new bike though, I do start fresh with new plugs.
New plugs won't make one side fire unless it's the plug itself. New plugs *might* run good for a bit if it's a carb problem it's temporary.
Air-gas-spark. CHeck your filter if you have one. Make sure it's not all clogged. If you don't have one there are relatively inexpensive ones you can get.
Sounds like you are getting gas.
Spark. Now I'm getting a bit older and when my eyes were newer this was far easier so now I do it somewhere it's darker. Pull the plug. Leave it connected. Ground the end to the head. (of the motor). Turn the bike over. You should be able to see the spark jumping across the end of the plug.
If not, there is your problem and you have to start tracing back to find where the problem is. I'm sure the guy who is going to help you with your carb can check this if you still aren't sure.
Ehonda
Pictures
Post by Ehonda » Fri May 20, 2011 9:08 am
IMAG0561 by Ehonda2011, on Flickr
Just some pictures I snapped last night my garage. Let me know your thoughts.
Ehonda
Intakes
Post by Ehonda » Fri May 20, 2011 9:09 am
Where are the carb intakes located on this bike?
brewsky
Re: Intakes
Post by brewsky » Fri May 20, 2011 9:45 am
Ehonda wrote:Where are the carb intakes located on this bike?
Remove the left side cover. There should be a door behind the battery (if it's still there) that covers the air cleaner. There's only one carb. Remove the silver carb cover to see more of the carb.
pknopp
Post by pknopp » Fri May 20, 2011 10:50 am
That's a very nice looking bike. Looks like it hasn't been messed with much of the years. Without question it's worth getting sorted out.
