Motorradfahrer
Post
by Motorradfahrer » Fri Apr 15, 2011 5:53 pm
Hello all!
I've been tinkering around with an old CL77 for a while now that had been sitting for a couple of years. The joint for the kicker is cracked and some of the teeth are worn down. I need to replace the part but haven't had any luck tracking down what I need. Perhaps one of you can point me in the right direction? I'd appreciate any input.
Thank you!
Dana01
Post
by Dana01 » Sat Apr 16, 2011 12:30 pm
Welcome to the forum Motor...
Please edit your profile to include your city. There are a number of us in your 'hood.
What year is your CL?
Dana
1966/7 CB-77 Red of course
Motorradfahrer
Post
by Motorradfahrer » Sun Apr 17, 2011 12:06 pm
It's a 1968.
Oops, I changed my profile info. I'm in Long Beach, CA.
Snakeoil
Post
by Snakeoil » Mon Apr 18, 2011 8:07 am
I have a spare with a similar crack. I believe it is from somebody trying to free the stuck engine by jumping up and down on the kick start.
I would watch ebay and make sure you ask if it is cracked or has any other issues. The crack on mine was not separated as yours is so not obvious without cleaning and close inspection.
I will ask around to see if anyone has a spare and let you know if I find one.
You can post a part wanted ad in that section. Guys with parts for sale tend to check it out regularly. I got my new levers posting there from Fast Fred.
regards,
Rob
Motorradfahrer
Post
by Motorradfahrer » Mon Apr 18, 2011 6:45 pm
Thank you for the suggestion. I'll check the classified ads.
rpr851r
Post
by rpr851r » Tue Apr 19, 2011 4:43 pm
I had the same problem. I did my best to grind out the crack and welded it up. After welding I turned the weld down on a lathe so the shaft was uniform in diameter. I got good weld penetration and I have my fingers crossed that it holds up. It will be a while before I know though.
