Newbie with 69 ca77 oil leak
maybe368
Post by maybe368 » Tue Apr 12, 2011 9:44 pm
Hello everybody. Been a member here for a short while and have gained a ton of knowledge just perusing all the threads. I searched my problem with no real good results, probably user error. I just got my 69 Dream running today after 20 years. She started right up and now is in need of a little adjustment. The problem is a pretty good oil leak coming from just below the alternator. I ran out of light and did not have time to pull the right side cover for a better look. Any ideas what it might be? What I should look for? Any help is greatly appreciated...Mark
Post by davomoto » Tue Apr 12, 2011 10:16 pm
Mark,
Please edit your loaction into your profile! There are 5 seals behind that cover. Remove the cover, clean it out really well, fire it up and try to see which one is leaking!
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
maybe368
Post by maybe368 » Tue Apr 12, 2011 10:28 pm
davomoto wrote:Mark,
Davo
I could not find the signature in my profile, where do I do that? Thanks I found this Image
Image by maybe368, on Flickr seal, @26, is that 1 of the 5? Thanks Mark
Post by davomoto » Tue Apr 12, 2011 10:31 pm
That shows one of the seals, the one in the starter sprocket. There is also a crankshaft seal, trans seal, clutch push rod seal, and gear shift drum seal. Go to your profile page, and there will be a line for "location".
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
maybe368
Post by maybe368 » Tue Apr 12, 2011 10:39 pm
davomoto wrote:That shows one of the seals, the one in the starter sprocket. There is also a crankshaft seal, trans seal, clutch push rod seal, and gear shift drum seal. Go to your profile page, and there will be a line for "location".
Davo
Thanks, I'll pull it off AGAIN tomorrow. Can these seals be replaced without disassembling the engine? I realize that some is required, but I am talking about dropping motor, splitting cases etc.? Thanks Mark
You didn't stop running because you got old, you got old because you stopped running
Post by davomoto » Wed Apr 13, 2011 12:13 pm
Yes, all of the seals can be replaced without droppping engine or splitting the cases. There is a guy on ebay that sells seal kits, might be a good idea to order one up, and change out all of those seals.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
maybe368
Post by maybe368 » Wed Apr 13, 2011 12:26 pm
Thanks, that is kind of what I thought. 1 more question. does the oil drain plug have a seal? mine does not and it is dripping. Thanks again...Mark
