it says to loosen the bolt on the engine and re tighten and an automatic plunger system will pick up the slack, but when i electric start my superhawk i can here the cam chain smacking around when its trying to fire up. it sounds awful. how can i get this chain slackless !!!!!!
http://a2.sphotos.ak.fbcdn.net/hphotos- ... 4717_n.jpg
adjusting cam chain problems !
Re: adjusting cam chain problems !
Ya sure it isn't the starter chain?. ...........lm
tavarama wrote:it says to loosen the bolt on the engine and re tighten and an automatic plunger system will pick up the slack, but when i electric start my superhawk i can here the cam chain smacking around when its trying to fire up. it sounds awful. how can i get this chain slackless !!!!!!
They are all the same length when new and are rather loose also.
Ya could install washers between the starter and the 4 bolts. .......lm
tavarama wrote:Ah yes thats what I meant. How can I adjust the slack if possible? I watched it as I was starting my bike and it was jumping all over and sounded like pennies in a blender. It only happens every so often
LOUD MOUSE wrote:They are all the same length when new and are rather loose also.
I tried doing that one time, and then the aluminum starter cover won't go back on as it messes up the alignment of the screw holes.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
okay LM. im back again about the smoke. my right side is def. not firing despite new splugs and i striped the wire doen and screwed the plug boot onto less worn wire. everything is set the the right adjustments. the smoke is coming from my engine internally from what i can see. it smokes immediately if it is warmed. is this a blown ring? i took my muffler off and noticed oil seeping out around end of muffler. how much does this cost to replace? i was contemplating an entire engine rebuild cause i doubt this engines gaskets have ever been replaced. yet is has less than 6000 miles on it. what would be the smartest direction to go?
