Right side poping
silverclerk@gmail.com
Right side poping
Post by silverclerk@gmail.com » Mon Mar 14, 2011 1:09 pm
Hey all,
I cannot figure out why the right side keeps popping. I had a little bit of a backfire which I attributed to the air mixture and idle being set wrong. Then I went for a ride and I couldn't get in to third gear without a sort of gurgling on the right side. First gear was fine and most of second until I got into the high revs. So, I took the carb off and set the float again, tightened (but not overtightened) the carb back on, made sure there were no air leaks around the intake boots, and also tightened down the right exhaust a bit. After that I could ride in 3rd gear but it's still popping a bit when coming off the throttle and coasting in gear. The right side is definitely running hotter because I checked and compared the right side spark plug to the left. Any ideas?
Post by davomoto » Mon Mar 14, 2011 1:39 pm
Have you done Ed's tune up recipie recently? Even if you have, do it again, and double check timing. Remove pilot jet and make sure it's clear, and adjust air screw once the bike is warmed up.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Post by silverclerk@gmail.com » Mon Mar 14, 2011 9:49 pm
Thanks Davo, I will re-do the tune-up and let ya' know how it goes. Appreciate the help.
Post by silverclerk@gmail.com » Mon Mar 21, 2011 9:29 pm
Well I redid the tuneup, still popping. So, I put a bigger idle jet in. The popping has decreased but not gone away and the performance has suffered a little. I also put new points in. Nothing has worked yet.
Narly9999
Could it be the condenser?
Post by Narly9999 » Tue Mar 22, 2011 5:15 am
Been getting fouled plugs and such in mine. I noticed the slightest bit of carbon on the plugs is arresting spark. Cleaned plugs replace and it works for a short time. Could a condenser cause this? I find this info on Condensers.
The history of the capacitor discharge ignition system can be traced back to the 1890s when it is believed that Nikola Tesla was the first to propose such an ignition system. In U.S. patent #609250 first filed February 17, 1897, Tesla writes 'Any suitable moving portion of the apparatus is caused to mechanically control the charging of a condenser and its discharge through a circuit in inductive relation to a secondary circuit leading to the terminals between which the discharge is to occur, so that at the desired intervals the condenser may be discharged though its circuit and induce in the other circuit a current of high potential which produces the desired discharge.'
Hmmm.
Post by davomoto » Tue Mar 22, 2011 8:35 am
silverclerk@gmail.com wrote:Well I redid the tuneup, still popping. So, I put a bigger idle jet in. The popping has decreased but not gone away and the performance has suffered a little. I also put new points in. Nothing has worked yet.
Valves adjusted? Compression tested? It is possible that old gas has etched the airways in the carb, and it needs to be replaced. I would remove the carb again, thoroughly clean and blow out all orfices, incluing the holes in the filter side bell, and see if that helps. Go back to the 42 pilot. Have you trimmed the ends of the plug wires back? About 1/4 inch off of all 4 ends will give you fresh wire, and try new plugs.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Post by LOUD MOUSE » Tue Mar 22, 2011 9:56 am
If the popping is the usual it can be adjusted out with the air screw in the proper setting with the slide.
May be out to many turns.135 and 42 jets may be of help. ........lm
