Will a CA95 front wheel fit on a CA77?
Cheburashka
Post by Cheburashka » Thu Mar 17, 2011 1:34 pm
Looking for a replacement wheel for the front of my '65 CA77. I've found one that's 16" and it's from a CA95. Is the rim narrower on the 150 than on the 305?
Thanks
Hoosier Tom
Post by Hoosier Tom » Thu Mar 17, 2011 4:17 pm
I believe the CA95 rims are narrower than the CA77 rims. You probably also have a difference in hub widths and diameters which will affect spoke angle. I have a pair of CA95 rims that I will measure tonight for you.
HT
Hoosier Tom
Post by Hoosier Tom » Thu Mar 17, 2011 11:17 pm
I did get the CA95 rims measured and they are 1.85 width just like the CA77 rims. The nipple angle looked different, though. You could try it if you wanted to roll the dice.
HT
Hippykid
Post by Hippykid » Fri Mar 18, 2011 2:29 pm
I was under the impression that they are the same rim but different hubs...just my 2 cents...
65 CA77
74 DT360
74 TY250
66 CA95
10 Honda Fury
Cheburashka
I'll wait
Post by Cheburashka » Mon Mar 21, 2011 10:53 am
Should be a decent one on Ebay some time soon.
mike1969
rim
Post by mike1969 » Mon Mar 21, 2011 11:37 am
Are you looking for a rust free 305 rim or one that is useable? I have one that has some pitting.
Cheburashka
I don't mind a bit of rust.
Post by Cheburashka » Mon Mar 21, 2011 12:34 pm
Just has to be round and true, or truable. Pits OK. Mine has a flat-spot and a chunk missing out of the brake lining (from an errant whack of the dead-blow hammer I was using to take out that flat spot).
PM sent.
