CA77 Kick Spindle Bushing Notch/Slot?
GeorgeP1111
Post by GeorgeP1111 » Tue Mar 08, 2011 5:40 pm
Ok, here's a dumb question.... What is the notch or slot in the Kick Spindle Bushing (#2 on the CA77 Diagram, #20 on the CB77) for? There is a matching slot in the upper engine case and I aligned the two of them today when I put the bottom back on my CA77 motor, but what is it's purpose? Oil feed for the bushing? Seems like if oil was the purpose they would have used a knock pin like they did in the bearings which would also be used to keep the bushing from turning (if that was a issue).
Anyhow, just thought I'd ask.
tnx
George
OldStan
Post by OldStan » Thu Mar 10, 2011 5:00 pm
You better look again. There is supposed to be a 7x12 knock pin that goes into the upper housing to keep that bushing from turning. There's a knock pin for the bushing on the other end too. I'll have to check my housing again, but I'm pretty sure it is an oil feed.
63 CA78
GeorgeP1111
Post by GeorgeP1111 » Thu Mar 10, 2011 6:28 pm
OldStan wrote:You better look again. There is supposed to be a 7x12 knock pin that goes into the upper housing to keep that bushing from turning.
Yup... Right you are. I checked my photos and knock pins on each end. It's there, I just forgot. I put all the knock pins in at the same time, then assembled the bottom end. When I was assembling the left case side, I remembered that slot and that was what prompted the posting.
Thanks for the "Wake-Up" notice :-)
George
OldStan
Post by OldStan » Thu Mar 10, 2011 6:39 pm
No problem, I'll probably need a wakeup call before I'm done. I've already been given a reality check or two. I should be getting the used transmission I ordered shortly. Hopefully I'll remember how everything goes as I reassemble. The best advise I got was to take plenty of pictures.
63 CA78
