As I posted in the introduction thread under Superhawk I have acquired a 1962 CB77 which needs a lot of work. It was last regestered in 1981 and I don't know if it was used off road after that. It has been in a shed since at least 1983.
From time to time I will post progress and pictures.
Here is what it looks like now.
Larry
Amissville, VA
1962 CB77 Rebirth log
- Michael Stoic
- Contact:
I'm not sure if I will bring it back to stock or not. I think I will get close.
The tank may be from a Goose but the previous owner and I arn't really sure. The handle bars are not stock and don't really fit the holders, they are to narrow between up sweeps jaming the holders. The wireing as been modified but I should have the factory harness in the box of goodies that came with the bike.
Side covers are any ones guess.
I have just removed the plugs and poured some mmo in the cylinders and turned it over slowly with the kick starter. It Moves, a good sign.
I wish I had micro fiche so I could see how things go together. I do have a factory, clymer (sp) and owners manuals but they leave something to be desired. My local dealer had given me a viewer and the fiche for my CL350 but when I checked with him yesterday I found that they had thrown all the old fiche away. Boy was I bummed.
Larry
Amissville, VA
Larry
Amissville, VA
Larry,
Looks like a great starting point. I'd do the major engine adjustments and services and fire it up as is before going crazy looking for missing parts. At least you can use it as you figure out what to do with it.
Post a picture of the tank and side covers. They look Italian (and familiar) to me, and if so, are probably valuable.
Matt
Matt,
I have 3 running bikes so using this one is not an issue. Also there is a small matter of a title. At the time the bike was registered in Vermont, Vermont was not a title state. The prior owner does not think he has the old reg so that will make it more difficult to title.
My plan would be to clean the carbs, put new plugs in since the old ones are broken and see if I can get it started.
The tank is said to be a Moto Guzzi, correction we think the tank is a Ducati. There are petcocks on each side of the tank.
Also the kick start lever does not look anything like the fiche so I am not sure it is standard either.
The bike was said to have been used to herd cows in Vermont and the person that gave me the bike said he received it in peices. I do know the frame and engine numbers are correct for the Superhawk.
Larry
Amissville, VA
Larry
Amissville, VA
Hey Larry,
Try this link.
http://www.crotchrocket.com/fiche_secti ... &fveh=3007
It takes you to a site that might be of some help in the parts diagram department. You can even print them all out if that helps.
I like the tank. Got me thinking how one might look on me CB500 cafe project.
Try this link.
