Oil filter gear
Dana01
- Contact:
Oil filter gear
I just tore the oil filter apart as I reassemble the clutch side. Turns out the rotor body was heated up and the small end and got crunched and flared out (previous post), the shaft was all gouged (the hidden inside portion), and the o-ring was crimped and pretty thrashed places. The inside was filled with greasy Aluminum particles and shavings. The gear was also free spinning on the rotor body.
Question: isn't the gear supposed to be an interference fit, and firmly in place?? I'm getting another assembly from Fast Fred, but I was wondering if the gear can be attached with epoxy or JB weld ... or should it be relegated to becoming a piece of motorcycle body jewelry or art?
And yes LM, I'm going to put the thrust washer on the outside ;)
Dana
1966/7 CB-77 Red of course
- h305 Moderator
Dana, I'd imagine that the sprocket is probably heat-fitted, much like a car starter ring gear onto the flywheel. We used to plonk the flywheel in the freezer for a couple of hours then heat the ring gear, whip the flywheel out and it just drops onto the shoulder. Let it all settle back to room temperature and Robert's Your Mother's Brother!
Dana01
- Contact:
YAY!
I finally found the culprit to the mysterious mangled oil filter (with Fast Fred's help).
When I took it all apart, the little shaft locator pin was missing. I assume the PO left it out. That enabled the shaft to spin and wobble thus causing excessive wear to the shaft and lots 'O heat to the boss and filter body. That worked the filter gear loose so that it spun freely about the filter body. That caused the oil to not be filtered. WOW!
However I don't think the PO changed the oil anyway. The filter was totally filled with greasy gunk and Aluminum particles.
Case closed.
Case closed.
Dana
That's what the filter is supposed to look like. It's a centrifuge design so it slings the heavy stuff to the outside and keeps it there. The aluminum probably came from the failure you are talking about. With the oil in there and the sprocket spinning at speed, that filter was spinning for sure. Might have been spinning with the shaft rather than on it, but it was spinning and working to some extent.
regards,
Rob
regards,
Rob
