Sticky Clutch ?
Sticky Clutch ?
Hi all,
Im almost done restoring my CB77 , and was busy with the clutch and cable.
While testing, I found that the clutch does not disengage , looks sticky from what I think.
But, is this 'normal' or 'common' for these old CB's that the clutch is kinda stuck when they have been sitting for a few month's ?
I know it's a pretty common problem for 70's or 80's CB's , but is it also common for the 60's bikes ?
I could not get it loose (rocking the bike a bit while holding the lever)
The engine has not started yet.
Anyway, is this a 'common' problem for the engine after sitting ?
Thank you :)
Thank you :)
Yes, fairly common! I have been able to unstick them by riding the bike a bit, and pulling and releasing the clutch lever while riding. You need to push off, or start on a downhill to take off with no clutch. Don't try this in traffic!
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Thanks, I know enough now :)
I have experience with this, so I know how to handle it.
I just wanted to make sure.
Best thing to prevent it from what I know is to start it and use the clutch once a week, lol :D
Thanks for the quick response, I need to update my project topic again, sorry for that.
jensen
- Contact:
I would consider taking off the clutch cover, remove debris, disassemble the clutch and check all parts. It's a little hard to understand why you wrote this and act not accordingly.
JensenIt's just there to keep big flying parts out.
Mostly the clutch plates make a mess, big chunks of 'rubber' can fly of and also tiny bits of metal.
If these bit's get sucked up by the (already) delicate oil pump, then the pump does not last long.
Just keep it there, you really need it.
The clutch plates generally create the most mess in any engine
Looks like the Engineer in ya is coming out there jensen. .......m
jensen wrote:Hi,
