neutral
Dgormley
Cable luber
Post by Dgormley » Sun Nov 28, 2010 8:01 pm
Davo, I've been using one similar to the Motion-pro luber for 25yrs..................D
Post by davomoto » Mon Nov 29, 2010 9:37 am
I've had the same one since 1979! Inexpensive and durable, gotta love it!
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
jensen
Post by jensen » Mon Nov 29, 2010 11:24 am
@ Steve,
In general lube the cables every year with High Density Telfon spray and a cable lube device, easy and simple. I go on spraying and pumping until it squirts out on the other side (of the cable).
Yes, that's the one, I use it for years now, and always good results.
Don't use it while the tachometer or speedo cable is attached,
