Hey Guys,
So I have a bit on an issue...
I replaced the internal throttle with a single pull cable throttle mechanism and it seems to be an issue as the exposed portion of the cable isnt long enough to fit in both the carb and the throttle housing... Thoughts?
-Sascha
braided lines...
Yes, I just did the operation yesterday. I heated up the ferrule with a lighter, slid it of off the housing. I then stripped off the plastic sheathing, and took a dremmel with a cut off wheel, and carefullully cut each loop of metal off without hitting the cable.
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
