Rear shock disassembly
rbaselt
Post by rbaselt » Fri Oct 01, 2010 8:28 am
I took these rear shocks apart for rechroming, and am wondering whether it is possible to remove the plunger shaft from the body (see photo below). Would I drill out the staked spots and then unscrew the metal ring by means of the two slots? Thanks,
Randall
rbaselt
Post by rbaselt » Sat Oct 02, 2010 10:50 am
One person said to drill out the staked spots, unscrew the slotted ring and pull out the plunger. Well, pulling out that plunger was a challenge. I had to rig up a tension device using a come-along between two 4 x 4 deck posts with the shock held by nylon ropes. Using an estimated 100 lbs of pull, that shock came apart with a pop and it sprayed black oil everywhere, despite having a catch basin underneath. Here's a photo of the internals:
mobilyte
Post by mobilyte » Mon Oct 18, 2010 1:51 pm
looks like you are missing the rubber "rear cushion stopper" on your shock
