engine blowby
Re: blowby
Post by LOUD MOUSE » Mon Oct 11, 2010 6:12 pm
No.
To the front if ya mean the ones in the gaskets.. ..................lm
mike1969 wrote:Oil at the top level without being screwed in. The vent holes on the upper part of the engine closer to the rider ( wrong?)
Post by davomoto » Mon Oct 11, 2010 6:18 pm
Mike, I did mean the holes in the aluminum plate, and two gaskets point to the front of the motor when installed. Sounds like Ed may have figured it out for you. Now you're gonna have to figure out how to get all of that beer to Ed's house. :-)
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
conbs
Blowby
Post by conbs » Mon Oct 11, 2010 6:22 pm
Since you did NOT have blowby when the engine was last assembled, but you do have it now, something has changed since then and I would guess Hotshoe is on the right track. Jensen recently started a thread that explains how he torques the head after a rebuild. 3 times.
Incorret installation of the vent holes in the gaskets/plate probably would not have had no blowby and then gotten worse. Would they?
It could also be your head or cylinders not being true, but that seems less likely to me since you had no blowby when first re-assembled. Yet, some combination of the torque/head problems might be the best explanation.
Anyone disagree?
Re: Blowby
Post by LOUD MOUSE » Mon Oct 11, 2010 6:23 pm
Yep. .....lm
conbs wrote:Since you did NOT have blowby when the engine was last assembled, but you do have it now, something has changed since then and I would guess Hotshoe is on the right track. Jensen recently started a thread that explains how he torques the head after a rebuild. 3 times.
Anyone disagree?
mike1969
blowby
Post by mike1969 » Mon Oct 11, 2010 6:32 pm
Guess I have the plate backwards. At least I won't have to pull the engine to fix that.
Conbs,I took the bike for a short spin and idled it after reassembly.At that point everything seemed ok.
I finally took it for a ride and stopped after about 5 miles.No problems then,everything dry.
Took it for the 5 mile return trip up the long hill and was blowing oil when I got back.
mike1969
blowby
Post by mike1969 » Thu Oct 14, 2010 9:44 am
Got the plate turned around with the holes to the front of the engine. Took it for a 3 mile ride but this time I went straight for the mile & half hill that always seems to push the oil out the vent hose.
Came back from the ride without loosing a drop of oil! Didn't have time to go any further but will take it on a longer ride this weekend and post the results.
Post by davomoto » Thu Oct 14, 2010 11:19 am
Mike, well done! You're tenacious, a good trait to have when fixing up old bikes!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
