- the smaller ID flanges for the two-piece exhaust systems with removable headers
the larger ID flanges for the one-piece systems
                    1965 Superhawk
Hi Lancaster
The Oil filter on this bike is a centrifugal one which mechanically spins the muck out of the oil. It's driven by a chain from the left hand crank end and lives under the cover with the three screws at the front of the primary chain case. You have to dismantle and clean this at regular intervals.
As for oil, best to search this site for a myriad of opinions on oil for these little machines. The suggestions will range from the original 30W oil recommended by Honda in the 50s and 60s up to modern synthetics. I'll stay on safe ground and suggest that whatever you use, that you change it as often as you can afford! Suffice to say that oil has developed as much over the last 50 or 60 years as all of the other branches of Engineering.....
'60 C77 '60 C72 '62 C72 Dream  '63 CL72
