where to begin??
arch379r
where to begin??
Post by arch379r » Thu Jul 08, 2010 7:14 am
final got my cb77 looking good and now trying to get it running good. it has been sitting for 15+ years,
the first problem appears to be if i start the bike and let it idle and pull the right spark pull wire off it has no effect on how the engine runs?? the more it runs and i pull the wire off it starts to have a little effect. it really appears to me to not fully running on both cylinders. i will do a full tune up b but thought maybe someone might have an idea on what to look for?
also how to i get to that tune up recipe thing i don't see anything in the FAQ section?
oh yea,I did clean out the carb jets.
houseowax
Post by houseowax » Thu Jul 08, 2010 7:28 am
The tune up recipe can be found in the FAQ section under the heading " How do I tune my factory stock motor on my CB72/77 or CL72/77 for optimum performance?".
I see you cleaned out your carb- Did you set your timing correctly? That's the step that I overlooked and it is absolutely crucial.
Now that you've got it looking good how about sharing some pics?
Good luck!
'63 CA77 - Giving me all kinds of headaches.
'64 CA77 - Patiently waiting it's turn
'65 CB77 - A 'great winter project'
cyclon36
Re: where to begin??
Post by cyclon36 » Thu Jul 08, 2010 9:25 am
arch379r wrote:final got my cb77 looking good and now trying to get it running good. it has been sitting for 15+ years,
have you tried pulling the left plug to see what happens?
Had the same problem when I first brought my CB77 home a few months ago. Turns out the timing was way off. That, and some new plugs fixed the issue.
Gunner_CAF
Post by Gunner_CAF » Thu Jul 08, 2010 10:41 pm
Welcome!
You can hold your hand behind the exhaust pipe, if cold air is coming out one side, that side it's not firing. I had similar problems the first time I started mine up. I used the FAQ and set the timing right. It has run like a champ ever since. If you havn't cleaned the carbs, it may be a good idea to do this first.
Update your profile and let us know what area of the world your from, and Post some pictures!!
Gunner
