Needle Jet Removal
Dr. Frankenstein
Needle Jet Removal
Post by Dr. Frankenstein » Sat Jun 05, 2010 2:35 pm
Does anybody know which way (and how) the needle jet on a 1964 CA77 comes out? Is it tapped out through the jet shaft, (where it would normally fall into the carb bowl), or tapped out the other way, where it would fall out through the carb needle/riser passage?
And my jets say 20 and 35; is this correct?
Thanks ya'll; it's hotter than hell in the garage today...
-John
Post by davomoto » Sat Jun 05, 2010 4:54 pm
John, tap it out from the top, towards float bowl. I'm not sure of jet sizes for CAs, but probably 120 and 35.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Dr. Frankenstein
Post by Dr. Frankenstein » Sun Jun 06, 2010 7:23 am
Thanks Dave; it looked like it could go either way,and I don't want to mash that delicate brass rim...and yes, they're 120 and 35, so at least I know I have the right jets...
Re: Needle Jet Removal
Post by LOUD MOUSE » Sun Jun 06, 2010 7:51 am
The brass main jet holder keeps the needle jet in place. .............lm
Dr. Frankenstein wrote:Does anybody know which way (and how) the needle jet on a 1964 CA77 comes out? Is it tapped out through the jet shaft, (where it would normally fall into the carb bowl), or tapped out the other way, where it would fall out through the carb needle/riser passage?
-John
