Some pics of the new bike, hopefully
17again
Post by 17again » Fri May 21, 2010 7:54 pm
I will try to post some shots of the barn find. I posted yesterday without any shots, so will try tonight.
17again
Post by 17again » Fri May 21, 2010 7:56 pm
Hey, it worked! Bike looks better in the photos than it really is! After the shots I took some fine steel wool and cleaned up the cases a bit and added bp blaster to the cylinders, hopefully they will unseize.
Does anyone know of a better product to use than BP blaster?
Thanks
rustywrench
Post by rustywrench » Sat May 22, 2010 12:54 am
Some stuff called kroil for creeping oil often found in NAPA stores works. But as for better, matter of opinion I suppose.
Wow, what a color combo. I love the pink seat. RW
onchiman
Post by onchiman » Sat May 22, 2010 8:04 pm
I've had good luck freeing stuck pistons with a 50/50 mix of ATF and Acetone. Put some in and put the spark plugs back in. Wait a while and try turning the rotor.
1963 Dream 305
17again
Post by 17again » Sat May 22, 2010 10:16 pm
thanks guys.
The pink seat is just the foam, no cover. Has any one bought the cheap seats from the Far East, or the one from Apex Cycle?
Onch, I thought I had read something about that but couldn't remember for sure. Where would one buy acetone? Isn't that nail polish remover? Where are you in the Adirondaks?
Thanks
onchiman
Post by onchiman » Sun May 23, 2010 7:02 am
I think most hardware stores sell acetone. I find it in the paint section usually and yes, I think it is in nail polish remover! I'm up near Lake Placid, 10 months of winter and two months of bad sledding.
1963 Dream 305
Gunner_CAF
Post by Gunner_CAF » Sun May 23, 2010 2:01 pm
17again wrote:thanks guys.
Thanks
On the seat, you are just missing the cover, and there are a few people who make these on e-bay. I repaired my cover so I don't know who sells the best seat cover. The cover is not that difficult to put on. The chrome trim is hard to find. I used self adhesive auto trim.
If you pull the thin pink layer of foam back, you can see the condition of the other foam. I rebuilt my seat using the existing foam. I used foam from a fabric store. It was not as firm as the existing seat foam so I used it to fill in the open spaces between the old foam. I used spray adhesive I also found at the fabric store to re-assemble the seat foam. I used a new sheet of thin foam to replace the top (pink) foam. After putting the cover back on, my seat turned out good, it was nice and firm.
You will also see a white piece of stiff foam on the seat back. Try to re-use this part. If you can't, I used some stiff thin sheets of self adhesive craft foam from a craft shop. I layered these until I had a good stiff replacement. If you have any questions on rebuilding the seat when you get to this, let me know. I may be able to find some pictures. It won't do you much good until you get your motor work done :)
Gunner
