CL77 engine base gasket surface
haydad57
Post by haydad57 » Wed Jan 13, 2010 7:58 pm
both sides of engine have sump at base of cylinder head front outer bolts for oil to drain to trans from top of engine. Mine ,I have have discovered during engine rebuild, have been filled in and machined with aluminum. Ever seen this? Are these sumps critical. Should I remove this material?
Re: CL77 engine base gasket surface
Post by LOUD MOUSE » Wed Jan 13, 2010 8:40 pm
What in the world do ya have there?
Most of these engines had the oil go up the feft and right front shafts to oil the total top end and that oil returned to the bottom by running down the center of all the top end parts.
What ya got there?. ..............lm
haydad57 wrote:both sides of engine have sump at base of cylinder head front outer bolts for oil to drain to trans from top of engine. Mine ,I have have discovered during engine rebuild, have been filled in and machined with aluminum. Ever seen this? Are these sumps critical. Should I remove this material?
haydad57
Post by haydad57 » Thu Jan 14, 2010 12:27 pm
LOUD MOUSE wrote:What in the world do ya have there?
Post by LOUD MOUSE » Thu Jan 14, 2010 7:13 pm
OK??????????????????. .............lm
Post by G-Man » Fri Jan 15, 2010 12:17 am
As LM says - the oil is fed UP the left and right front studs to the valve gear. The return to the sump comes via the cam chain tunnel etc. So for your motor, has someone rigged up an external feed to the head? Otherwise the cams will run dry with disastrous results.
haydad57
Post by haydad57 » Fri Jan 15, 2010 8:46 am
Somebody filled engine case returns on either side with solder. I cleaned it out. Right side is critical because some return oil is used to lube right main it appears.Left main gets oil directly from transmission.I don't know whos idea the solder was or what they were trying to. Engine had scored left cam and rocker arms. Maybe they were trying to increase oil pressure,I dont know! I found plugged rocker arm shafts on left.Repaired all that and cleaned out solder. Now I'm good as new.
