'63 CB77 fork disassembly, help!
maia
Post by maia » Fri Jan 01, 2010 6:45 pm
I need to get the Front fork seal housing off for re-chroming and I'm not getting much help from my " Clymer " Can anyone help? There are 4 " knock fork piston pins " if that's what they are, in the housing that look like they need to be removed to get the seal housing off and also to get at the fork seals which also need replacing, Am I right? I could drill them out I suppose but what to replace them with when reassembling. Seems like a pretty difficult situation for something that needs to be periodically replaced or maybe I'm just missing something....any hep would be appreciated. thanks
marzini
Post by marzini » Fri Jan 01, 2010 7:19 pm
'62 CB77, '76 XT500
Post by davomoto » Fri Jan 01, 2010 8:34 pm
I've sucessfully used a strap wrench to unscrew the chrome seal holders, or a proper pin wrench will remove them with ease.
maia
Post by maia » Fri Jan 01, 2010 8:38 pm
So does that mean it's threaded? If a strap wrench or pin wrench works that would indicate it's threaded or does that just snap off the pins? Thanks, I'll just give it a try.
Post by davomoto » Sat Jan 02, 2010 2:27 pm
Yes, threaded
maia
Post by maia » Sat Jan 02, 2010 7:46 pm
Thanks Davo...love or money or a pin wrench could not get that sucker lose so I ended up cutting a slot through the threaded portion and then tried the pin wrench and it worked . What a mess! I guess that's what sitting in a carport for 30 odd years will do to you. The internals of the fork look good but the seal housing is in rough shape and I can't get one of the stanchions out of the lower leg for some reason. I think I might leave well enough alone as everything looks good and works smoothly. I hope someone has seals, I'll try my usual sources. On top of the seal is 33 46 10x4. Thanks for your help.
maia
Post by maia » Sun Jan 03, 2010 1:12 pm
Anyone have any ideas why I can't remove the stanchion from the fork leg? The other leg came right apart after I removed the seal housing but this one works smoothly in the leg but will not come out all the way. Doesn't seem to be corrosion in there stopping it.
