Part number for standard bore rings 65 dream
joeweir1
Post by joeweir1 » Wed Mar 08, 2006 9:45 am
I wanted to verify part number for standard bore rings for my 65 CA77. The number I have is 13010-275-000.thanks
CR93Dave
rings - Part Number
Post by CR93Dave » Wed Mar 08, 2006 1:00 pm
That part number is for standard size ring set for the 305 CA/CB/CL77
and that part is still stocked by American Honda.
CR93Dave
joeweir1
CA77 rings
Post by joeweir1 » Thu Mar 09, 2006 9:46 am
Ther are early and late Dreams. The early take different rings. Is there a vin# cut off that denotes what constitutes early and late Dreams? I don't have a parts book yet and I know sometimes they will show where the cut-off is. thanks
piecutter
Post by piecutter » Thu Mar 09, 2006 5:53 pm
The thick rings were used up to Eng.# 0210151 according to American Honda. They are also available. 13010-266-000 But you want to be sure, if you have an engine before that number, it could have been rebuilt with the newer style pistons. It's easy enough to tell the difference, if I recall correctly, the old ones are thick one piece rings with holes cut at angles through the sides of them. The newer ones look like typical modern rings.
joeweir1
Rings
Post by joeweir1 » Thu Mar 09, 2006 7:23 pm
It seems that all rings I see on ebay are the old style. I guess the older engines are not as plentiful anymore. thanks
