12N9-3A vs 12N9-4B for Superhawk
Spargett
Post by Spargett » Thu Dec 03, 2009 1:16 pm
I need to replace my Superhawk's 12N9-3A battery. Unfortunately there aren't any locally. There is quite an abundance of 12N9-4B's though. They seem to be marketed towards the CB160 - CB200's. I checked the stats on the two and the only difference I could see was that the 12N9-4B was barely shorter.
Thoughts?
12N9-4B
12N9-4B
12N9-3A
12N9-3A
Post by davomoto » Thu Dec 03, 2009 1:52 pm
Try Batteries +. That's where I get my batteries for CL and CBs. There has to bew a few of them in Sac.
Davo
Gunner_CAF
Post by Gunner_CAF » Thu Dec 03, 2009 9:04 pm
I ordered one at Ohio Cycle ($30). It didn't come with electrolite so I took it to the local battery store and had it filled.
Gunner
Spargett
Post by Spargett » Thu Dec 03, 2009 9:21 pm
Thanks for the tips guys. I more curious on a theoretical level. My knowledge of batteries is limited.
eyhonda
Post by eyhonda » Thu Dec 03, 2009 10:56 pm
I think the difference between the 'a' & 'b' is the polarity. I got the better quality Yusa YB9B. I plan to relocate the battery, so polarity isn't an issue. Even with the stock wiring setup, the wires were long enough to reach the flipped connections.
63 cb77 cafe
www.eyhonda.com
Spargett
Post by Spargett » Fri Dec 04, 2009 2:03 pm
Looks like you nailed the difference. Where are you placing the battery? Is this for the CB77 or the 175?
eyhonda wrote:I think the difference between the 'a' & 'b' is the polarity. I got the better quality Yusa YB9B. I plan to relocate the battery, so polarity isn't an issue. Even with the stock wiring setup, the wires were long enough to reach the flipped connections.
eyhonda
Post by eyhonda » Sat Dec 05, 2009 4:19 pm
It's specified for a 175 but is dimensionally the same. This version of the battery holds the charge a little longer. All the info is at the Yuasa site. If I'm keeping the bike, I prefer Yuasa. I haven't mounted it yet but it fits in stock battery box. I plan on a cafe seat. So I will make a bracket to mount it under the hump area.
63 cb77 cafe
www.eyhonda.com
