My engine is now completely disassembled and I spent several hours yesterday cleaning the cases in a big parts cleaning tank.  I' not at all happy with the result - there  is still quite a bit of corrosion and gunk.  Having rubbed off much of the old paint with my brass brush I'll need to repaint the engine anyway, so I'm thinking of bead blasting it now.
Can I do it in parts or should I wait until the engine is re-assembled?  I wouldn't want to damage gasket mating surfaces with blasting.
What is the best medium to use?
Would it be worth buying a cabinet or is it cheaper/better to send the work out?  What kind of vendor does media blasting anyway?
Thanks.
                    Prepping engine for paint?
				FiremanBob
i bought a sandblasting cabnet disassembled my 305 engine blasted it clean  put cases in a part cleaning tank then used brake clean to hose down engine cases anr used compressed air to blow off cases and all oil galleys then i powdercoated engine cases cylinder,cylinder head and covers a dull silver. engine looks great have a pic on my 63 dream come true restortation project under busaken
