CRAZY SPEEDOOO
miand
CRAZY SPEEDOOO
Post by miand » Sun Aug 09, 2009 7:06 pm
I have a 1967 CB77, I bought a new speedometer cable and hooked it up for the first time since owning the bike. everthing seemed to be working fine for the first 20 miles, but then it started to bounce wildly, then peg out to 110 mph and make a mild grinding noise. Has anyone had this problem, and/or know what the problem is. I appreciate any help.
Post by G-Man » Mon Aug 10, 2009 12:37 am
Miand
Sounds like the bearing on the input to the speedo has dried out so that your new cable winds up then goes 'twang' as it gives way - whizzing the needle around. You need to take the speedo off and turn the input with a small flat screwdriver to see if it turns freely. If not, try a little lube. You may have killed the spring in the speedo, like the one in the picture below.
If so you need either a good speedo repairer or a replacement. The pictures are from a dismantled speedo. You don't need to go this far just to twiddle the input shaft. If you spin the shaft in the right direction, the speedo needle will move briefly. If it's still reading 110, then it's all over.
Spring has been damaged
This is a working speedo
miand
Post by miand » Mon Aug 10, 2009 7:15 pm
It seems to turn freely and its not stuck at 110 so I am going to try to lube it up. Thanks for advice!
Post by G-Man » Tue Aug 11, 2009 12:13 am
Might be worth greasing the speedo cable too. Especially if it was a NOS one.
Post by G-Man » Sat Aug 22, 2009 6:54 am
Did it work?
miand
Post by miand » Sat Aug 22, 2009 9:14 am
I took it apart and put some lite oil on the bearing and spring and greese on the cable. it works great. Went for a 25 mile ride and it was perfect. thanks so much for the tip!
Post by G-Man » Sat Aug 22, 2009 9:04 pm
Glad that it helped.
Lovely looking bike you have there.
