Brake light switch?
RonBou
Brake light switch?
Post by RonBou » Fri May 08, 2009 1:43 pm
Just got my 66 Dream running again after a 2 year storage. Started right up! The brake light works but I have to just about stand on the pedal to get it to light up. I figured a simple adjustment but for the life of me I can't find a brake light switch. Where should I be looking? Thanks for any help you can give me.
Re: Brake light switch?
Post by LOUD MOUSE » Fri May 08, 2009 2:19 pm
Inside the RIGHT SIDE removable cover. ................lm
RonBou wrote:Just got my 66 Dream running again after a 2 year storage. Started right up! The brake light works but I have to just about stand on the pedal to get it to light up. I figured a simple adjustment but for the life of me I can't find a brake light switch. Where should I be looking? Thanks for any help you can give me.
Post by 305 » Fri May 08, 2009 2:28 pm
on my 1966 CA77 305 Dream it is on the LEFT side under the cover , in front of the battery
RonBou
Post by RonBou » Fri May 08, 2009 3:14 pm
Thank you both... I will take both covers off. :)
RonBou
Post by RonBou » Fri May 08, 2009 3:33 pm
Yup... Do I turn the whole switch to adjust it? I don't want to break anything experimenting.
Post by 305 » Fri May 08, 2009 4:13 pm
i wouldn't try turning it because there are wires attached to it. on mine the switch is threaded and sticks into a hole in a bracket , then jam nuts on each side of the hole..... loosen one, tighten the other
RonBou
Post by RonBou » Fri May 08, 2009 4:21 pm
I went out to the garage a minute ago with my glasses on and used a drop light and it was immediately obvious how to adjust it. Thank you.....
