The bottom ring is obvious, but the top two on mine were indiscernibly different. New set looks just like what's in the photo. Thanks in advance.
P.S. I tried to search the forums in advance, I couldn't find anything.
Spargett wrote:I was curious as to the order of piston rings. I found this photo below, but I just wanted to check with you guys to make sure that it's correct. Just because someone put a picture of it on the internet, doesn't always mean it's right ; )
LOUD MOUSE wrote:LOCATIONS ARE CORRECT. BE SURE NUMBERS ARE UP. ...........lm
Spargett wrote:Thanks for the info guys. LM, not sure what you mean by the "numbers up".
Davo, thanks, saw reference to that in Bill Silver's manual. Always appreciate the reminders.LOUD MOUSE wrote:YOU WILL SEE NUMBERS ON THE RIGHT SIDE OF THE OPEN END IF YOU HAVE THE RING "TOP UP". ..........lm
davomoto wrote:Also, be sure to put the end gaps 120 degrees apart.
