Oil Guide
djbarcy
Oil Guide
Post by djbarcy » Wed Sep 21, 2005 1:56 pm
Re-aquired my '65 305 Dream about 7 years ago, tore it down, tagged and bagged the parts, and am finally finishing up the restoration.<br />I have found everything but the &quot;oil guide&quot; (PT# 25571-259-000, also part #15 on page 70 of Bill Silver's guide)<br />Also, can't quite figure it's placement and/or function.<br />Any help would be greatly appreciated.<br /><br /><br />
Dan Barcy
'65 305 Dream
Re: Oil Guide
Post by LOUD MOUSE » Wed Sep 21, 2005 5:38 pm
The part fits into the clutch lifter joint which fits into the end of the shaft before the pressure plate is installed. Be sure to replace the rubber &quot;O&quot; ring in the end of the shaft or oil will come out the other end of the shaft. .....................
RIDE IT DON'T HIDE IT!
djbarcy
Re: Oil Guide
Post by djbarcy » Thu Sep 22, 2005 12:05 pm
Thanx LM.<br />Was wondering if anyone has a picture of one that they can post? Would help me in looking back through all my pieces parts to see if maybe I overlooked it.<br />Just finish mounting up the motor and would like to forge ahead.<br />dan
Dan Barcy
'65 305 Dream
djbarcy
Re: Oil Guide
Post by djbarcy » Tue Sep 27, 2005 1:59 pm
Well, tore the place apart again and still no oil guide.<br />I will attempt to manufature my own but need some detailed specs, pix, diagrams please.<br />From the schematic it looks like a tube with a washer on the end and has a notch fro the pin.<br />But, I have no idea about length, hole size, if it is hollow all the way thru.<br />It also looks like it goes in after the plate/springs are installed. If so, what holds it in place.<br />I also don't see an o ring in the schematic.<br />Any additional help would be appreciated as this is the last piece it looks like I need before close her up.<br />Thanx<br />dan
Dan Barcy
'65 305 Dream
djbarcy
Re: Oil Guide
Post by djbarcy » Tue Sep 27, 2005 2:38 pm
While I was typing the previous message Martin Knight emailed me that West Hills Honda had 12 of the parts in stock.<br />made the phone call and they are on thier way.<br />Thanx<br />dan
Dan Barcy
'65 305 Dream
Re: Oil Guide
Post by LOUD MOUSE » Tue Sep 27, 2005 2:53 pm
The &quot;O&quot; Ring is in the end of the Main Shaft. Part #23211-259-010 and the number for the &quot;O&quot; ring is 91305-259-000. This MUST be tight on the Clutch Lifter Joint (the part that you need fits inside this part) so oil will not come out the shaft. ..........LM
FLYHAVEN2001
Re: Oil Guide
Post by FLYHAVEN2001 » Tue Sep 27, 2005 6:11 pm
Mouse are you talking about the oil seal in right side end of the shaft or on the left end of the shaft I only have seen seals , not orings in these unless I'm missing something.I'll have to look again at one I have apart.
