New Superhawk Owner
Gunner_CAF
Re: rear brake cable
Post by Gunner_CAF » Fri Mar 06, 2009 9:57 pm
jleewebb wrote:retrobikes sez they'll have the rear brake cables in stock by end of March.
Good news. Thanks!
Gunner
Post by e3steve » Sat Mar 07, 2009 4:41 am
Gunner, thanks to you, too (as well as Spargett & jleewebb), for your detailed resto posting. Inspiration indeed!
Gunner_CAF
Post by Gunner_CAF » Tue Mar 10, 2009 12:44 am
Today a round package, and a square package were waiting for me after work. My tires, cables, and other parts from Retro Bikes came, and the foot peg bracket from Fast Fred. We put the new tires on and cleaned up the bracket. We couldn't stop so we put the front fender, tire, rear swing arm and center stand on tonight. We figured it was time to quit. We want to save some fun for tomorrow.
Gunner
Post by e3steve » Tue Mar 10, 2009 7:30 am
Cheng Shins? Or is RB selling other makes? I'm reluctant to go the Cheng Shin route, as the road surfaces here in Majorca aren't exactly grippy, even in the dry (high flint / granite content, to cope with the Summer heat). I'm still looking for some classic-looking Dunlops.
I'm a bit of a purist, but I do like that cropped front fender!
Gunner_CAF
Post by Gunner_CAF » Tue Mar 10, 2009 11:27 pm
They are Cheng Shins.
Gunner
Gunner_CAF
Post by Gunner_CAF » Wed Mar 11, 2009 12:22 am
Tonight I ran a ground wire through the rear fender and put bullet connectors on each end. I grounded a wire to the tail light and added another bullet connector to this. I plan to run a copper ground to everything. We mounted the tail light, then put the rear fender and rear wheel on.
Gunner
Ground with Bullet Connectors
Gunner_CAF
Post by Gunner_CAF » Thu Mar 12, 2009 10:55 pm
The Motor when in tonight. I didn't have a much help as Lee had, so I had to improvise :) It was the reverse of how we took it out. We raised the cycle jack all the way and pushed it up to the work bench, then lowered the motor on the jack. With my son steadying the motor, I lowered the jack and motor, then rolled it under the frame. I lifted it up until the bolt holes lined up. The picture below, we just inserted the front bolt. Then we used the jack to position the motor for the remaining bolts. It worked quite well.
Gunner
Motor Installation.
Motor Installation.
