                    Stuck nut!!!!
				FLYHAVEN2001
Re: Stuck nut!!!!
You do not have to take the nut off if your taking chain off and if your splitting case. Just split the case and then you can lift out clutch gear assy and clutch hub assyand you have enough slop in chain to remove the chain.
