???????????6mm "special nut and sealing washer"
eyedragaknee
- Contact:
Bolting case halves together on a CL77 and the books call for a special nut and sealing washer on one of the 6mm studs next to the oil pump outlet. Anybody have a pic of where this actually goes and what it looks like and if a standard nut with a shoulder and a sealing washer wouldn't work as well.
Thanks
Thanks
Re: ???????????6mm "special nut and sealing washer"
The nut is that tall one with the closed end and the washer is aluminum. ...........lm
eyedragaknee wrote:Bolting case halves together on a CL77 and the books call for a special nut and sealing washer on one of the 6mm studs next to the oil pump outlet. Anybody have a pic of where this actually goes and what it looks like and if a standard nut with a shoulder and a sealing washer wouldn't work as well.
Thanks
RIDE IT DON'T HIDE IT!
eyedragaknee
- Contact:
Special nuts
That is NUTS
Thanks guys. I can make one now.
What were they thinking? Just wanted to make a nut with a flat bottom to take a washer and that is what they came up with?
Re: Special nuts
It seals the channel where all the oil from the pump heads to the engine parts which need it. ..........lm
eyedragaknee wrote:That is NUTS
eyedragaknee
- Contact:
sealing nut
I love those little Asian engineers. They think of everything!!!!
