I started to rebuild my Dutch 1964 CB72 after a seizure 10 years ago. As my oil pump was rotating difficultly, I took it apart. There was a small part of steel jamming the gears which made two scratches below the gears (see picture).
Should I replace the oil pump; and if I have to, where can I get another oil pump?
Rob
Should I replace my oil pump?
Re: Should I replace my oil pump?
Yes you should replace the pump.
I have ones I've inspected and are good to go. .........................lm
strikef1 wrote:I started to rebuild my Dutch 1964 CB72 after a seizure 10 years ago. As my oil pump was rotating difficultly, I took it apart. There was a small part of steel jamming the gears which made two scratches below the gears (see picture).
Rob
RIDE IT DON'T HIDE IT!
