                    Hagons, anybody fitted them
				toastyhamster
And found they don't fit?  The top cover is too wide and fouls on the frame, looks like I'll have to make some spacers.
				toastyhamster
CB72, seems odd that yours fit.  Any chance you could measure the circumference of the top cover for me?  If the cover was 3-4mm lower on the shock then it would miss the frame completely, it's just going to catch the frame under the shock mount.
Pic here:
http://www.toastyhamster.plus.com/susp.jpg
						Pic here:
				toastyhamster
Hi
Not sure what the 63mm and 70 mm top cover means ..
I measured my Hagons and what I take to be an original Honda damper ( least it has the
plastic top shroud and came with a pile of CB72/77 bits ). I've quoted the actual measurements
but obviously they are approximate subject to manufacturing tolerances, paint etc..
Diameter of top shroud - Hagon = 2.3" Honda = 2.3" ( = 58.42mm ) maybe this is the 63mm ?
Circumfrence = @7+1/4" measured ( 7.23" calculated = 183.6mm )
The biggest difference between the Hagons and the Honda units is the width of the top mounting.
If I measure only the metal "eye" excluding the rubber bush then I get:
Hagon = 0.65" ( 16.5mm )
Honda = 0.88" ( 2.35mm )
This would mean that the Honda unit sits further away from the frame if you push it as far on
as it will go. If you do the same with the Hagon then it will probably sit closer to the frame and
be slightly cocked over.
The lower mountings measure the same across the forked ends.
I think you will be OK if you put a spacer on the top mounting bolt before putting the damper
on. If you line up the bottom end first you should be able to measure how much you need to
space the top out.
cheers
Phil
space the top out.
cheers
Phil
