Top End Rebuild: Location of O-rings...
305explr
Post by 305explr » Thu Sep 04, 2008 9:11 pm
After a summer of distractions, I'm back at it and almost done with my engine rebuild. Silver says the green o-rings go around the locater pins that are between the cylinders and the cam unit. I'm fine with that.
Are there o-rings that go around the pins that are between the case and the cylinders, or is the gasket all I need? My diagrams are unclear on this and Silver says nothing (which might be a hint).
Advice appreciated.
Re: Top End Rebuild: Location of O-rings...
Post by LOUD MOUSE » Thu Sep 04, 2008 9:58 pm
They go on the knock pins at each front corner between the head and cylinders. ..........lm
305explr wrote:After a summer of distractions, I'm back at it and almost done with my engine rebuild. Silver says the green o-rings go around the locater pins that are between the cylinders and the cam unit. I'm fine with that.
Advice appreciated.
RIDE IT DON'T HIDE IT!
305explr
Post by 305explr » Fri Sep 05, 2008 4:24 pm
Thanks!
