Clutch Rod Interference?
Dogsbd
Post by Dogsbd » Mon Aug 11, 2008 8:43 pm
Test fitting the right hand side case cover today it seemed that the clutch lifter rod was sticking out too far and I could not push the cover one because of it. What is it that I may have done (in clutch assembly I assume) to cause this?
1966 CA77
joeweir1
Post by joeweir1 » Mon Aug 11, 2008 9:00 pm
Clutch adjuster installed wrong in the side cover would be my first guess.Have a photo?How far out is the rod sticking?Did you have the clutch apart?
Dogsbd
Post by Dogsbd » Tue Aug 12, 2008 6:49 am
Yes, I did have the clutch apart. The rod sticks out past the gear 2 - 2.5 inches. I'll try to get a picture or two this evening.
joeweir1
Post by joeweir1 » Tue Aug 12, 2008 3:40 pm
can you push in on the rod at all?
Dogsbd
Post by Dogsbd » Tue Aug 12, 2008 4:07 pm
joeweir1 wrote:can you push in on the rod at all?
I cannot.
Here is the picture:
Dogsbd
Post by Dogsbd » Wed Aug 13, 2008 8:39 am
I think I have it sorted, removed the clutch and reinstalled and it seems to work fine now.
Thanks
joeweir1
Post by joeweir1 » Wed Aug 13, 2008 9:59 pm
ok
