Installed new wiring harness two wires don't match??
BrewCityDream
Post by BrewCityDream » Mon Jun 16, 2008 12:37 am
Hi I installed a new wiring harness purchased on EBAY but two of the wires don't match. Anyone know the correct color association? I attached pictures of the mystery wires pink and brown from the cycle. Blue and white on the new harness. It's a 1964 CA 305 dream. All the other wires on the harness matched perfectly. Right now I have pink to blue and white to brown although I have no idea if that is correct. My dream is not starting yet as I just removed starter and kick starting did'nt work either prior to that. Prior to removing starter today I got a click when pushing starting button and with wires connected in both configurations.
Re: Installed new wiring harness two wires don't match??
Post by LOUD MOUSE » Mon Jun 16, 2008 4:48 am
What does your wiring diagram show the pink and brown wires connect to?
Where do the blue and white connect at the other end?. ...........lm
BrewCityDream wrote:Hi I installed a new wiring harness purchased on EBAY but two of the wires don't match. Anyone know the correct color association? I attached pictures of the mystery wires pink and brown from the cycle. Blue and white on the new harness. It's a 1964 CA 305 dream. All the other wires on the harness matched perfectly. Right now I have pink to blue and white to brown although I have no idea if that is correct. My dream is not starting yet as I just removed starter and kick starting did'nt work either prior to that. Prior to removing starter today I got a click when pushing starting button and with wires connected in both configurations.
RIDE IT DON'T HIDE IT!
BrewCityDream
Post by BrewCityDream » Mon Jun 16, 2008 7:59 pm
I only have a techincal wiring schematic and it's not clear where they come from or go to.
kustommusic
Post by kustommusic » Mon Jun 16, 2008 8:15 pm
Try this; Pink goes from the ignition switch to the dynamo. Brown goes from the dynamo to the rectifier. Nothing to it,right? Good Luck, Kustommusic
