Ca77 rectifier wires
tomcat2821
ok I Got 3 wires hooked up on my switch can anyone tell me where the yellow, pink wire from the rectifier hooks to on the switch I have a 3 position switch witch have 4 place for wires Bat, starter, ACC, IGN ok I got the battery red wire, the ING black with white tube coming from the nutral switch and black coming from the ignition coil I have a diagram but it shows 8 hook ups my switch only has 4 is there any place they can go on my switch plus there is a brown wire from the meter lamp, green wire from the horn button but these arent that important than the yellow and pink wire from the rectifier <br /><br />also I am not getting fire to the plugs maybe coil or points bad dont know what else could keep from getting fire any help would be appretiated thanks
kustommusic
Re: Ca77 rectifier wires
Tom, Mabey it would be easier to get the proper CA switch for your bike. Not trying to give you a hard time but it sure would make things more straight forward on the pesky wiring. Besides I save my "hard times" for Ryan. <br /> I wouldn't worry about getting fire to the plugs till you have the key switch business straight. That will probably fix your ignition problems too. Good Luck! Steve Greer
tomcat2821
so you are telling me I have the wrong switch b/c it was on the bike when I got it it was hooked up but I didnt have a key so a friend of mine unhhoked the wires from the switch and then left and if so where can I get this switch thanks for the reply
ryan_siefrin
- Contact:
<br /><br />LOL, WOW, all the other broken parts that i have tried to sale in the past have never come back to haunt me like this headlight has.kustommusic wrote:<br />Tom, Mabey it would be easier to get the proper CA switch for your bike. Not trying to give you a hard time but it sure would make things more straight forward on the pesky wiring. Besides I save my "hard times" for Ryan. <br /> I wouldn't worry about getting fire to the plugs till you have the key switch business straight. That will probably fix your ignition problems too. Good Luck! Steve Greer<br />
Ryan Siefring
1965 Honda CA77 Dream
1996 Honda CBR 900 RR
ryan_siefrin
- Contact:
<br /><br />Try ebay for your switch, i've seen many on there or ohiocycyle.com or classiccycle.com<br /><br />latatomcat2821 wrote:<br />so you are telling me I have the wrong switch b/c it was on the bike when I got it it was hooked up but I didnt have a key so a friend of mine unhhoked the wires from the switch and then left and if so where can I get this switch thanks for the reply<br />
Ryan Siefring
