CA77 battery cover
CA77 battery cover
Members, is anyone aware of two different sizes of battery cover for the CA77 as mine doesn't fit close to the framework but is about 1/2" away.
- IMG_4325.JPG (174.62 KiB) Viewed 2307 times
Re: CA77 battery cover
Glad to see we are up and running with being able to post photos again
There were 2 different size batteries, along with different side covers and frame slots etc.
I really don't see anything wrong with yours from the pic?
The parts lookups will give the serial breakdown of the changeover.
Early had a wider battery and later smaller version. I don't think the early one is manufactured anymore, just some old OEM's turn up occasionally on e bay.
Hi brewsky, that is not my bike only to demonstrate how the cover should fit close to the frame.
Oh, OK...
The early frame slots look to be much wider, so the early covers may not fit in the late slots?
How about a pic of yours?
oops not quick enough on the trigger!
Looks like you have a late cover in an early frame, or maybe not....a little hard to see as the paint is mirror glossy!
How about a side view?
Looks like 1010863 is the changeover serial#
The more I look at it, the more it looks like the bottom tab on the cover is bent inward.
It should be pretty much flush with the outside profile of the cover.
- cover.jpg (293.13 KiB) Viewed 2289 times
