PW26 Drain Screw Fiber Washer
deuce_7
Post by deuce_7 » Sat Jul 06, 2019 9:32 am
Related to the PW26 carb discussions posted here over past several weeks;
The original PW26 fuel bowl (square bowl) drain screw gasket is a very thin fiber washer with a small surface area to seal the screw to the bowl drain port radius. My CL77 has the stock steel drain screws (not the kit replacement brass with wide head & surface area), and O-rings don't work well/tend to distort and crush.
Dimensions of the original Keihin drain bowl red fiber washer:
o.d.: 8mm
i.d.: 6mm
So the actual sealing area under the drain screw area is 1mm all the way around.
Those small fiber washers apparently aren't a typical hardware store or auto parts store item.
Any one have a source for these small red fiber washers?
Tim Allman
Post by Tim Allman » Sat Jul 06, 2019 10:30 am
Have a look here: https://spaenaur.com/catalog/D10/
Although all the fibre washers are inch sized, there seems to be a good range of them and there's always a bit of wiggle room with washers anyway. Note that they also have washers in soft metals like copper that might also work.
I'm fortunate enough that I can visit their sales desk and get advice from the clerks. Perhaps there's a similar company near you.
deuce_7
Post by deuce_7 » Sun Jul 07, 2019 9:55 am
Thank you for the catalog link; this can be a valuable resource. I see a couple of possibilities. I'll have to look locally to see what's available in this product line.
Much appreciated.
