                    Oil seal kick start shaft
I've replaced all the oil seals on right side except the kick start shaft. Does any one have a quick tip on how to remove old seal? This is on a 65 CL 77
						Re: Oil seal kick start shaft
I've have had luck removing oil seals with a paint can opener.  I put a screwdriver through the handle.  Just be careful not to damage anything other than the old seal.
						GTC wrote:I've replaced all the oil seals on right side except the kick start shaft. Does any one have a quick tip on how to remove old seal? This is on a 65 CL 77
