Carb part needed.
CL77butcher
Carb part needed.
I need a float bowl for a 68 CL77 kei-hin carb, mine had a pin hole that I re-flowed with silver but the heat warped the bowl and I don't think it will last long. Please help, I don't want to buy a whole carb over a warped bowl. :)
Re: Carb part needed.
DANG!!!!!!!!!!!!!!!
I misread and thought all he needed was a float.
J.B. Weld will fix the bowl. ................lm
These folks have them cheap. .......lm
<http://www.olypen.com/retro/>
CL77butcher wrote:I need a float bowl for a 68 CL77 kei-hin carb, mine had a pin hole that I re-flowed with silver but the heat warped the bowl and I don't think it will last long. Please help, I don't want to buy a whole carb over a warped bowl. :)
For future reference, you cannot solder on carbs, Butcher. You can fix pin hole with an epoxy. Make sure it is epoxy and not polyester resin. You should make a test sample and soak it in modern gasoline first to see if it will be affected by the fuel.
The carbs are either aluminum or zamac, which is a zinc alloy.
regards,
Rob
regards,
Rob
