bullet connectors
OldStan
bullet connectors
Post by OldStan » Wed Jun 10, 2015 6:20 pm
Is there a source for the proper bullet connectors for the 305's? The ones I find in the store are larger. I found a couple headlights that match my CL77, but the bullet connectors on them are smaller. I could use them for other repairs as well.
63 CA78
s2000erick
Post by s2000erick » Wed Jun 10, 2015 9:01 pm
They have the larger and smaller connectors, http://www.vintageconnections.com/
OldStan
Post by OldStan » Thu Jun 11, 2015 7:24 pm
Thanks, those should work. I also ordered some gray sleeving for my headlight switch wiring I've been needed.
63 CA78
OldStan
Post by OldStan » Mon Jun 15, 2015 7:20 pm
Got the bullet ends and sleeving today. Ends work perfectly. The sleeving was a perfect size match to replace the cover for the wires to the light switch. I also got some of the larger size and replaced the cover on the main harness from the headlight to the coils. The old one was stiff and broken in three spots, this is flexible, should last much better. I'll probably use some on my CA77 harness where it's bad as well.
63 CA78
bamacl
Post by bamacl » Mon Jun 22, 2015 8:30 pm
I reworked my entire harness on the CL with their stuff. Looks and works really good. At the same time I added grounds for the lights and ran inside the new sleeve.
