Honda Parts Number Cross Reference Table
hondacubber
Post by hondacubber » Fri Nov 25, 2011 12:52 pm
Thanks
Some sellers have the wrong picture for 18391-259-000 There is some one Ebay now in Thailand.
Eric
Post by LOUD MOUSE » Fri Nov 25, 2011 1:08 pm
The early issue looked like a Sleeve with a Large end.
It was red but was changed to black.
The next issue was a red "O" ring sort of seal then that was was changed to black. ............lm
hondacubber wrote:Thanks
Eric
billsey
Post by billsey » Wed Feb 01, 2012 1:09 am
hondacubber wrote:The bikes you list would seem like likely fits. The gasket pictures I find for 18391-259-000 show a red o-ring type gasket. The C723963 gaskets I am trying to ID are black and about 1.5" long with a large collar on one end. It looks similar to one I got for a C100 exhaust pipe.
I've seen the gasket you describe on the CB160 pipes, between the header and the muffler. The number for the early CA77 is a 18391-259-000 PACKING, MUFFLER but the images I see for that is the red gasket you describe. The same part for the dry sump models (C75 and C76) is 18391-250-000 C70 PACKING, MUFFLER and looks like what you describe. You probably need to measure the diameter of your part to verify it's the 250/305 size and not the smaller 150/160 size. I'm guessing the part number you have doesn't actually match the part...
