Lost spark..
danielzink
Lost spark..
Post by danielzink » Wed Mar 29, 2017 1:06 pm
I know this been re-hashed a thousand times...but...
Took the bike out for it's first run in probably 20 years...
Ran it up and down the street a few times...came back into the garage to adjust the idle and -bleh- it stalled out...
Checked all the usual suspects...fuel (yep)....battery (12+v)....12v to points (yep)....
I did the old "remove the boot and stick a screw in the wire and hold it 1/4" from the cylinder head" trick...nothin'...
I took some 220 paper and cleaned up the point contact then polished it with some 600...
She ran for about a minute...while it was running I noticed that the points were "sparking" quite a bit...and actually spitting out tiny sparks...
It shut down again and now...no spark...
Anything else I should check or should I just pony up for some new points ? maybe electronic ignition ?
Thanks, Dan
Re: Lost spark..
Post by LOUD MOUSE » Wed Mar 29, 2017 1:16 pm
After you used the 600 grit did you spray the point contacts then pull a business card through them?
Condenser???. .............lm
danielzink wrote:I know this been re-hashed a thousand times...but...
Thanks, Dan
danielzink
Re: Lost spark..
Post by danielzink » Wed Mar 29, 2017 1:48 pm
LOUD MOUSE wrote:After you used the 600 grit did you spray the point contacts then pull a business card through them?
Thanks, Dan
Well...
It's been an hour or so....I went back out and 600 polished them again...hit 'em with some Bra-Kleen and this time I "did" run a business card through...
And it fired up.
I don't have any more time today to ride it so It'll have to wait until tomorrow or the weekend before I can test it out.
I hope it's not the condenser...that thing is mounted in a crazy spot :O
Thanks again !
Dan
Post by G-Man » Wed Mar 29, 2017 2:25 pm
Dan
You could wire in a new condenser without removing the old one. If it fixes it you can swap them over in the knowlerdge that you are not wasting your time.
casamere
Post by casamere » Thu Mar 30, 2017 1:16 pm
Agree with G-Man on this one with the condenser. I assume you are getting plenty of petrol through.
